メインコンテンツにスキップ
Motorola Moto 360 Case Locking Fastener Replacement
必要な工具と部品
  1. Motorola Moto 360 Case Locking Fastener Replacement, Wrist Strap: 手順 1、 1の画像 1
    この手順で使用する道具:
    購入する
    • Locate the spring-loaded pin that attaches the wrist strap to the watch.
    • There is a tiny groove on the end of the pin. This is where you will place the tweezers.
  2. Motorola Moto 360 Case Locking Fastener Replacement: 手順 2、 1の画像 1
    • Take care not to lose the spring-loaded pin when removing the strap.
    • Use the tweezers to compress the spring-loaded pin so the strap can be removed.
  3. Motorola Moto 360 Case Locking Fastener Replacement: 手順 3、 2の画像 1 Motorola Moto 360 Case Locking Fastener Replacement: 手順 3、 2の画像 2
    • Pull the wristband away from the watch face.
  4. Motorola Moto 360 Case Locking Fastener Replacement, Case Locking Fasteners: 手順 4、 1の画像 1
    • Locate the rectangular end of the fastener inside the wrist strap mounting pocket.
  5. Motorola Moto 360 Case Locking Fastener Replacement: 手順 5、 2の画像 1 Motorola Moto 360 Case Locking Fastener Replacement: 手順 5、 2の画像 2
    • Push the point of the pin in behind the fastener and pry it out. There is a notch near the end of the fastener which will engage the pin. Once the end pops out, the fastener will slide out of the slot easliy. Repeat to remove all four of them.
    • That's it. Now the two halves of the watch can be easily separated by just pulling gently with your fingers.
終わりに
18 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Chris K.
メンバー登録日: 02/27/17
661 ポイント
1ガイドが承認済み
9 件のコメント
I lost my fasteners... where can I buy more?
thiagopimenta - 返信
One misleading thing about this guide: pictures show the back cover taken off, while in fact you don't need to do this -- just take out the fasteners.
Дмитрий Трубин (Dmitry Trubin) - 返信
Absolutely correct, you don't need to heat or take the back off. I will say though that getting those clips out was damnably fiddly for me.
Ethan Duffy -
ou peut acheter Case Locking Fastener Replacement pour moto360 mon bracelet tien pas
svp chez besoin case locking fastener
abellegarde - 返信
don't remove the back!
follow this video for removing the locking pins.
I did it, so can you!
https://www.youtube.com/watch?v=Jw3n5qbG...
davidlanchart - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 27
今までの合計 7,583
