メインコンテンツにスキップ
Motorola MOTO W755 Cell Phone Top Panel Replacement
必要な工具と部品
  1. Motorola MOTO W755 Cell Phone Top Panel Replacement, Battery: 手順 1、 2の画像 1 Motorola MOTO W755 Cell Phone Top Panel Replacement, Battery: 手順 1、 2の画像 2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 2、 2の画像 1 Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 2、 2の画像 2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: 手順 3、 3の画像 1 Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: 手順 3、 3の画像 2 Motorola MOTO W755 Cell Phone Top Panel Replacement, Top Panel: 手順 3、 3の画像 3
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  4. Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 4、 3の画像 1 Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 4、 3の画像 2 Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 4、 3の画像 3
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
  5. Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 5、 2の画像 1 Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 5、 2の画像 2
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
  6. Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 6、 1の画像 1
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  7. Motorola MOTO W755 Cell Phone Top Panel Replacement: 手順 7、 1の画像 1
    • You now have the top panel completely detached.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Roberta Glenn
メンバー登録日: 07/11/12
43 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012人のメンバー
CPSU-REGAN-SU12S1G3
2 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 11
今までの合計 1,938
