メインコンテンツにスキップ
Motorola MOTO W755 Cell Phone Main Logic Board Replacement
必要な工具と部品
  1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: 手順 1、 2の画像 1 Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: 手順 1、 2の画像 2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 2、 2の画像 1 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 2、 2の画像 2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Main Logic Board: 手順 3、 1の画像 1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  4. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 4、 2の画像 1 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 4、 2の画像 2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  5. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 5、 3の画像 1 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 5、 3の画像 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 5、 3の画像 3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  6. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 6、 1の画像 1
    • Remove the plastic covering completely from the body of the phone.
  7. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 7、 2の画像 1 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: 手順 7、 2の画像 2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
終わりに
作成者
4人の作成者と共同で作成されました。
C Miller
メンバー登録日: 06/25/12
56 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 1-3, Regan SU 2012 Cal Poly, Team 1-3, Regan SU 2012人のメンバー
CPSU-REGAN-SU12S1G3
2 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,501
