メインコンテンツにスキップ
Motorola Lapdock 100 Screen Replacement
必要な工具と部品
  1. Motorola Lapdock 100 Screen Replacement, Lower Case: 手順 1、 2の画像 1 Motorola Lapdock 100 Screen Replacement, Lower Case: 手順 1、 2の画像 2
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. Motorola Lapdock 100 Screen Replacement: 手順 2、 1の画像 1
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Screen Replacement: 手順 3、 1の画像 1
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. Motorola Lapdock 100 Screen Replacement: 手順 4、 2の画像 1 Motorola Lapdock 100 Screen Replacement: 手順 4、 2の画像 2
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  5. Motorola Lapdock 100 Screen Replacement: 手順 5、 2の画像 1 Motorola Lapdock 100 Screen Replacement: 手順 5、 2の画像 2
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  6. Motorola Lapdock 100 Screen Replacement: 手順 6、 3の画像 1 Motorola Lapdock 100 Screen Replacement: 手順 6、 3の画像 2 Motorola Lapdock 100 Screen Replacement: 手順 6、 3の画像 3
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  7. Motorola Lapdock 100 Screen Replacement: 手順 7、 2の画像 1 Motorola Lapdock 100 Screen Replacement: 手順 7、 2の画像 2
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
  8. Motorola Lapdock 100 Screen Replacement, Battery: 手順 8、 2の画像 1 Motorola Lapdock 100 Screen Replacement, Battery: 手順 8、 2の画像 2
    • Unplug battery from motherboard.
  9. Motorola Lapdock 100 Screen Replacement: 手順 9、 1の画像 1
    • Remove the battery.
  10. Motorola Lapdock 100 Screen Replacement, Screen: 手順 10、 2の画像 1 Motorola Lapdock 100 Screen Replacement, Screen: 手順 10、 2の画像 2
    • Disconnect the two wires that attach to the screen.
  11. Motorola Lapdock 100 Screen Replacement: 手順 11、 1の画像 1
    • Now flip the lapdock back over. Using a plastic prying tool, unclip and remove the small plastic cover at the top of the lapdock.
  12. Motorola Lapdock 100 Screen Replacement: 手順 12、 1の画像 1
    • Insert wisdom here.
  13. Motorola Lapdock 100 Screen Replacement: 手順 13、 1の画像 1
  14. Motorola Lapdock 100 Screen Replacement: 手順 14、 2の画像 1 Motorola Lapdock 100 Screen Replacement: 手順 14、 2の画像 2
    • Remove the four 3.5 mm long phillips head screws from the two screen flanges holding the screen.
    • The screen should be free from the lapdock after doing the prior step.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Anthony Aiumu
メンバー登録日: 01/12/16
770 ポイント
7のガイドは作成済み
チーム
Eastern Washington University, Team 1-3, Rowley Winter 2016 Eastern Washington University, Team 1-3, Rowley Winter 2016人のメンバー
EWU-ROWLEY-W16S1G3
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 767
