メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
To start your lapdock disassembly, you will need to start by removing the keyboard. After this is completed, you will need to remove the screws located underneath the keyboard. Then you will remove the four screws underneath the lapdock to remove the bottom case. This will give you access to the internal components of the device.
  1. To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed. You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  5. Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the  ribbon cable. Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the  ribbon cable.
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  6. After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws. After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  7. Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom. Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom. Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  8. Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case. Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
終わりに
ある他の人がこのガイドを完成しました。
Jessica
メンバー登録日: 2016年01月12日
197 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-3, Rowley Winter 2016 Eastern Washington University, Team 1-3, Rowley Winter 2016人のメンバー
EWU-ROWLEY-W16S1G3
4 メンバー
8のガイドは作成済み
コメント1件
This helps with the opening up but what about inside? I need to replace the charging port and can find no part number or a decent marking.
Ian Leigh - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 259
