メインコンテンツにスキップ
Motorola Krzr K1m LCD Replacement
必要な工具と部品
  1. Motorola Krzr K1m LCD Replacement, LCD: 手順 1、 2の画像 1 Motorola Krzr K1m LCD Replacement, LCD: 手順 1、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Begin by removing the trim piece from around the front face plate.
    • Be very careful when dealing with the trim. It is very delicate, so be cautious when approching this next part.
    • Using your fingers or The Spudger get underneath the trim. Start by applying enough force to pry the trim off.
    • Be patient when trying to pry off the trim. The tape attaching the trim to the phone is very strong. Just be persistent and patient and it will eventually give.
    • Remove the trim piece.
  2. Motorola Krzr K1m LCD Replacement: 手順 2、 2の画像 1 Motorola Krzr K1m LCD Replacement: 手順 2、 2の画像 2
    • Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
  3. Motorola Krzr K1m LCD Replacement: 手順 3、 2の画像 1 Motorola Krzr K1m LCD Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Gently use The Spudger towards the edge of the phone and lift the face plate off.
    • The touch-sensitive keys and chip board/LCD screen (which is green) may remain attached to the face plate because of the glue.
    • Gently hold the green logic board down as you lift the face plate apart from it.
    • Remove the face plate.
  4. Motorola Krzr K1m LCD Replacement: 手順 4、 3の画像 1 Motorola Krzr K1m LCD Replacement: 手順 4、 3の画像 2 Motorola Krzr K1m LCD Replacement: 手順 4、 3の画像 3
    • Gently, with your fingers or a tweezer, lift the orange flex cable apart from the pin connector it is connected to.
    • Gently remove the green logic board/LCD (Liquid Crystal Display) screen away from the phone.
    • Replace with new green logic board/LCD screen.
    • To reassemble the phone, follow of the steps in reverse order.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Jennifer Hudiono
メンバー登録日: 01/13/10
42 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-1, Forte Winter 2010 Cal Poly, Team 11-1, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S11G1
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 6,548
