メインコンテンツにスキップ
Motorola Krzr K1m Flex Cable Replacement
必要な工具と部品
  1. Motorola Krzr K1m Flex Cable Replacement, Battery: 手順 1、 2の画像 1 Motorola Krzr K1m Flex Cable Replacement, Battery: 手順 1、 2の画像 2
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. Motorola Krzr K1m Flex Cable Replacement: 手順 2、 1の画像 1
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  3. Motorola Krzr K1m Flex Cable Replacement: 手順 3、 1の画像 1
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
  4. Motorola Krzr K1m Flex Cable Replacement, Keypad: 手順 4、 2の画像 1 Motorola Krzr K1m Flex Cable Replacement, Keypad: 手順 4、 2の画像 2
    • Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
    • Remove the battery.
  5. Motorola Krzr K1m Flex Cable Replacement: 手順 5、 3の画像 1 Motorola Krzr K1m Flex Cable Replacement: 手順 5、 3の画像 2 Motorola Krzr K1m Flex Cable Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    Spudger
    $3.99
    • To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
    • Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
    • Remove the battery dock by popping it up with The Spudger.
  6. Motorola Krzr K1m Flex Cable Replacement: 手順 6、 3の画像 1 Motorola Krzr K1m Flex Cable Replacement: 手順 6、 3の画像 2 Motorola Krzr K1m Flex Cable Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    • To remove the chip board, first unplug the flex cable from the logic board with tweezers.
    • Lift up the logic board from the bottom flip with your fingers.
    • Remove the logic board.
  7. Motorola Krzr K1m Flex Cable Replacement: 手順 7、 2の画像 1 Motorola Krzr K1m Flex Cable Replacement: 手順 7、 2の画像 2
    • Gently pop off the keypad with your fingers.
    • Once the keypad is removed, follow all of the steps in reverse order to replace the old keypad with the new keypad.
  8. Motorola Krzr K1m Flex Cable Replacement, Flex Cable: 手順 8、 1の画像 1
    • Remove the small silver screw located where the top of the back of the phone.
  9. Motorola Krzr K1m Flex Cable Replacement: 手順 9、 1の画像 1
    • Then take out the small grey plastic cap indicated in the picture.
    • do not lose the cap!
  10. Motorola Krzr K1m Flex Cable Replacement: 手順 10、 2の画像 1 Motorola Krzr K1m Flex Cable Replacement: 手順 10、 2の画像 2
    • Next, turn the frame on it's side and gently tap it till the hinge cover that was screwed in falls out.
    • Then use your flathead to push here. Be careful! Apply a little force but not too much or else the left hingecover you're pushing out here may shoot out and get lost.
  11. Motorola Krzr K1m Flex Cable Replacement: 手順 11、 2の画像 1 Motorola Krzr K1m Flex Cable Replacement: 手順 11、 2の画像 2
    • Push in the white thing in the middle, it's spring-loaded, and pull the frame halves apart.
    • DO NOT LOSE THE BLACK HINGE RING. you need it.
  12. Motorola Krzr K1m Flex Cable Replacement: 手順 12、 2の画像 1 Motorola Krzr K1m Flex Cable Replacement: 手順 12、 2の画像 2
    • Then slide out the flex cable.
    • Slide in the new flex cable the same way you took it out.
    • And congratulations you are done!
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jennifer Hudiono
メンバー登録日: 01/13/10
42 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-1, Forte Winter 2010 Cal Poly, Team 11-1, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S11G1
5 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 13
今までの合計 10,546
