メインコンテンツにスキップ
Motorola Entice w766 Motherboard Replacement
必要な工具と部品
  1. Motorola Entice w766 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Slide the tab off the back of the device.
  2. Motorola Entice w766 Motherboard Replacement: 手順 2、 1の画像 1
    • Use the tab located at the top of the battery to release the battery.
  3. Motorola Entice w766 Motherboard Replacement, Motherboard: 手順 3、 3の画像 1 Motorola Entice w766 Motherboard Replacement, Motherboard: 手順 3、 3の画像 2 Motorola Entice w766 Motherboard Replacement, Motherboard: 手順 3、 3の画像 3
    • The six screws need to be taken out with any conventional screw driver tool.
    • You will have to unscrew the six 5.31 mm Star Head #5 screws with the appropriate six star bit.
    • There should be six screws removed from the casing after completion.
  4. Motorola Entice w766 Motherboard Replacement: 手順 4、 3の画像 1 Motorola Entice w766 Motherboard Replacement: 手順 4、 3の画像 2 Motorola Entice w766 Motherboard Replacement: 手順 4、 3の画像 3
    • First you will need to locate the lip on the left side of the device.
    • Next you will insert the black spudger firmly into side opening to loosen the casing.
    • Using the blue pry tool gently remove the black and silver casing.
    • The motherboard should then be exposed after removal.
  5. Motorola Entice w766 Motherboard Replacement: 手順 5、 3の画像 1 Motorola Entice w766 Motherboard Replacement: 手順 5、 3の画像 2 Motorola Entice w766 Motherboard Replacement: 手順 5、 3の画像 3
    • Remove the flex cable with a pair of tweezers.
    • Be gentle with the flex cable as not to break the connecting wire.
    • Now use a spudger or pry tool to place firmly under the motherboard.
    • After creating clearance with the spudging device grab and remove the motherboard with a clamping tool or hand.
    • Look at the motherboard for scorches or loose pieces which could indicate damage.
    • Refer to the troubleshooting page for further advice to replace the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Aalan Miranda
メンバー登録日: 09/29/16
210 ポイント
2のガイドは作成済み
チーム
IUPUI-Harley-F16S2G4 IUPUI-Harley-F16S2G4人のメンバー
Community
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 213
