メインコンテンツにスキップ
Motorola E815 Keypad Replacement
必要な工具と部品
  1. Motorola E815 Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Keypad Replacement: 手順 2、 1の画像 1
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Keypad Replacement: 手順 3、 2の画像 1 Motorola E815 Keypad Replacement: 手順 3、 2の画像 2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Keypad Replacement, Disassembling Motorola E815 Antenna: 手順 4、 1の画像 1
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 Keypad Replacement: 手順 5、 2の画像 1 Motorola E815 Keypad Replacement: 手順 5、 2の画像 2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Keypad Replacement, Keypad: 手順 6、 1の画像 1
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using a T6 Screwdriver.
  7. Motorola E815 Keypad Replacement: 手順 7、 3の画像 1 Motorola E815 Keypad Replacement: 手順 7、 3の画像 2 Motorola E815 Keypad Replacement: 手順 7、 3の画像 3
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Carefully detach the two sections of the phone.
  8. Motorola E815 Keypad Replacement: 手順 8、 3の画像 1 Motorola E815 Keypad Replacement: 手順 8、 3の画像 2 Motorola E815 Keypad Replacement: 手順 8、 3の画像 3
    • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
    • Gently remove the keypad frame from the keypad.
    • Lift the silicone keypad cover off.
  9. Motorola E815 Keypad Replacement: 手順 9、 2の画像 1 Motorola E815 Keypad Replacement: 手順 9、 2の画像 2
    • Rotate the phone around so that you are looking at the battery cavity.
    • Locate the screws on the bottom base of the phone.
  10. Motorola E815 Keypad Replacement: 手順 10、 2の画像 1 Motorola E815 Keypad Replacement: 手順 10、 2の画像 2
    • Rotate the phone back to the front side.
    • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  11. Motorola E815 Keypad Replacement: 手順 11、 3の画像 1 Motorola E815 Keypad Replacement: 手順 11、 3の画像 2 Motorola E815 Keypad Replacement: 手順 11、 3の画像 3
    • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
    • Separate the keypad from the circuit board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Zoie E
メンバー登録日: 01/12/11
603 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 14-8, Forte Winter 2011 Cal Poly, Team 14-8, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S14G8
5 メンバー
5のガイドは作成済み
2 件のコメント
We should have a motherboard replacement.
Santi12008 - 返信
We need to fullify more this content.
Santi12008 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 2,099
