メインコンテンツにスキップ
Motorola Droid X Rear Case Replacement
必要な工具と部品
  1. Motorola Droid X Rear Case Replacement, Rear Case: 手順 1、 1の画像 1
    • Objective: remove the rear case from the Motorola Droid X phone.
    • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
  2. Motorola Droid X Rear Case Replacement: 手順 2、 1の画像 1
    • INSTRUCTION: Turn the phone over so that the back faces up.
  3. Motorola Droid X Rear Case Replacement: 手順 3、 1の画像 1
    • Objective: remove the battery casing plate.
    • The case plate has a push and slide mechanism.
  4. Motorola Droid X Rear Case Replacement: 手順 4、 1の画像 1
    • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
    • INSTRUCTION 2: Slide down the battery case plate.
  5. Motorola Droid X Rear Case Replacement: 手順 5、 1の画像 1
    • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
  6. Motorola Droid X Rear Case Replacement: 手順 6、 1の画像 1
    • Objective: remove the battery from the battery compartment.
  7. Motorola Droid X Rear Case Replacement: 手順 7、 1の画像 1
    • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
  8. Motorola Droid X Rear Case Replacement: 手順 8、 1の画像 1
    • Objective: remove two small black screws from the back of the phone.
    • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
  9. Motorola Droid X Rear Case Replacement: 手順 9、 1の画像 1
    • INSTRUCTION: Remove two black screws from the back of the phone.
  10. Motorola Droid X Rear Case Replacement: 手順 10、 1の画像 1
    • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
    • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
  11. Motorola Droid X Rear Case Replacement: 手順 11、 1の画像 1
    • INSTRUCTION: Flip the phone over to the front side.
  12. Motorola Droid X Rear Case Replacement: 手順 12、 1の画像 1
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
  13. Motorola Droid X Rear Case Replacement: 手順 13、 1の画像 1
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
  14. Motorola Droid X Rear Case Replacement: 手順 14、 1の画像 1
    • Objective: remove four white screws from the corners of the screen.
    • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
  15. Motorola Droid X Rear Case Replacement: 手順 15、 1の画像 1
    • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
  16. Motorola Droid X Rear Case Replacement: 手順 16、 1の画像 1
    • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
  17. Motorola Droid X Rear Case Replacement: 手順 17、 1の画像 1
    • Objective: remove the rear case from the phone in order to provide access to inside the phone.
    • The phone is now held together by the casing alone. You need to pop the two halves apart.
  18. Motorola Droid X Rear Case Replacement: 手順 18、 1の画像 1
    • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
  19. Motorola Droid X Rear Case Replacement: 手順 19、 1の画像 1
    • Now you are ready to access the internal circuits of the phone.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Anna
メンバー登録日: 10/08/12
28 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Voss Fall 2012 Ohio State, Team 1-1, Voss Fall 2012人のメンバー
OSU-VOSS-F12S1G1
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 885
