Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
Pry the back cover up with the plastic opening tool to free the plastic clips.
Continue prying along the left edge of the back cover towards the top of the phone.
Work the plastic opening tool across the top of the back case to free the plastic clips.
The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
Continue prying down the right side of the back cover to free the remaining clips.
Pull the back cover away from the phone to remove it.
The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
The battery must remain in the phone and not come off with the back cover or you will break the power lead.
Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Remove the two 3.3 mm T5 Torx battery terminal screws.
Grab the blue battery removal tab and lift the battery out to remove it.
There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
Gently pry up the bottom edge of the camera cover with a plastic opening tool.
Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
Remove the six screws securing the rear case to the rest of the phone:
three 6.7 mm silver T3 Torx screws at the top,
four 4.0 mm gold T3 Torx screws in the middle,
and three 4.5 mm black T5 Torx screws at the bottom.
Insert a plastic opening tool between the rear case and the motherboard assembly.
Work your way down the side of the phone and gently pry the rear case up.
Separate the rear case from the motherboard assembly.
There is a small metal shield that covers the display assembly cable connectors on the motherboard. This shield is held in place by a few small clips that attach to the surrounding EMI shields.
Use the tip of a spudger to gently bend the clips out of shape and remove the shield.
Use a heat gun or hair dryer to soften the adhesive strip around the perimeter of the motherboard.
Pry the edges of the motherboard up from the display assembly with a plastic opening tool.
Remove the motherboard assembly.
Lift up the anti-static tape covering the camera and earpiece ZIF connectors with the tip of a spudger.
Peel back the tape and remove it.
Unless you have spare ESD-safe tape lying around, you may consider keeping this piece somewhere safe to be reused at reassembly.
Use a plastic opening tool or your fingernail to lift up the tab on the rear-facing camera ribbon cable ZIF connector.
Make sure you're prying on the tab and not the connector itself.
Push the rear-facing camera through its hole in the grey antenna and remove it.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
