メインコンテンツにスキップ
Motorola Droid RAZR M Battery Door Glass Lens Replacement
必要な工具と部品
  1. Motorola Droid RAZR M Battery Door Glass Lens Replacement, Battery Door Glass Lens: 手順 1、 1の画像 1
    • Shattered!
  2. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 手順 2、 1の画像 1
    • Glass won't just pop off. It is held by a very sticky tape. Carefully scraping the tape with the glass pieces off and vacuum the area after to prevent a clean surface.
    • Be aware of jumping tiny glass pieces during process. Protect your eyes and area around you. They can get stuck in skin too.
  3. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 手順 3、 1の画像 1
    • To replace the part you first need to attach the sticky tape. It comes in the correct outlines. Take the inner parts out to keep those areas free (Camera, Flash, Loudspeaker and a hole).
    • Before you take the film off practice the attaching. You will have it hard to reposition after its attached. Same goes with the lens itself, practice before the tape film is off. Once you feel safe to go, peel the film off and go for it!
  4. Motorola Droid RAZR M Battery Door Glass Lens Replacement: 手順 4、 1の画像 1
    • Done :-)
ゴール
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Alex R
メンバー登録日: 09/27/13
215 ポイント
1ガイドが承認済み
3 件のコメント
This is not a razr maxx !!!!
Fausto Lebron - 返信
This isn't a Razr Maxx. The back doesn't have glass on a razr maxx.
Alex Tucker - 返信
This is Droid razr m . not maxx
Qais Afridi - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 7,377
