メインコンテンツにスキップ
Motorola Droid RAZR Camera Cover Replacement
必要な工具と部品
  1. Motorola Droid RAZR Camera Cover Replacement, Back Cover: 手順 1、 2の画像 1 Motorola Droid RAZR Camera Cover Replacement, Back Cover: 手順 1、 2の画像 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Camera Cover Replacement: 手順 2、 3の画像 1 Motorola Droid RAZR Camera Cover Replacement: 手順 2、 3の画像 2 Motorola Droid RAZR Camera Cover Replacement: 手順 2、 3の画像 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Camera Cover Replacement: 手順 3、 3の画像 1 Motorola Droid RAZR Camera Cover Replacement: 手順 3、 3の画像 2 Motorola Droid RAZR Camera Cover Replacement: 手順 3、 3の画像 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Motorola Droid RAZR Camera Cover Replacement, Battery: 手順 4、 2の画像 1 Motorola Droid RAZR Camera Cover Replacement, Battery: 手順 4、 2の画像 2
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Motorola Droid RAZR Camera Cover Replacement: 手順 5、 3の画像 1 Motorola Droid RAZR Camera Cover Replacement: 手順 5、 3の画像 2 Motorola Droid RAZR Camera Cover Replacement: 手順 5、 3の画像 3
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Motorola Droid RAZR Camera Cover Replacement, Camera Cover: 手順 6、 2の画像 1 Motorola Droid RAZR Camera Cover Replacement, Camera Cover: 手順 6、 2の画像 2
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Motorola Droid RAZR Camera Cover Replacement: 手順 7、 3の画像 1 Motorola Droid RAZR Camera Cover Replacement: 手順 7、 3の画像 2 Motorola Droid RAZR Camera Cover Replacement: 手順 7、 3の画像 3
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
David Hodson
メンバー登録日: 04/13/10
152,760 ポイント
127のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 4,782
