メインコンテンツにスキップ
Motorola Droid Pro Keyboard Replacement
必要な工具と部品
  1. Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 手順 1、 2の画像 1 Motorola Droid Pro Keyboard Replacement, SD Card/SIM Card PCB Board: 手順 1、 2の画像 2
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Keyboard Replacement: 手順 2、 1の画像 1
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Keyboard Replacement: 手順 3、 1の画像 1
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Keyboard Replacement: 手順 4、 2の画像 1 Motorola Droid Pro Keyboard Replacement: 手順 4、 2の画像 2
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Keyboard Replacement, Screen: 手順 5、 1の画像 1
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Keyboard Replacement: 手順 6、 1の画像 1
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
  7. Motorola Droid Pro Keyboard Replacement, Keyboard: 手順 7、 1の画像 1
    • Pop out key board using a spudger on the marked points.
    • The keyboard is locked in place, but can pop in and out. You may need to use a little force to get it out.
    • Once out you can pop the new keyboard in the opposite way you took it out.
終わりに
作成者
6人の作成者と共同で作成されました。
Peter Cakounes
メンバー登録日: 10/21/14
19 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S5G8
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 203
