メインコンテンツにスキップ
Motorola Droid MAXX 2 Rear Camera Replacement
必要な工具と部品
  1. Motorola Droid MAXX 2 Rear Camera Replacement, Battery: 手順 1、 1の画像 1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Rear Camera Replacement: 手順 2、 1の画像 1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Rear Camera Replacement: 手順 3、 2の画像 1 Motorola Droid MAXX 2 Rear Camera Replacement: 手順 3、 2の画像 2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Rear Camera Replacement: 手順 4、 1の画像 1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Rear Camera Replacement: 手順 5、 1の画像 1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Rear Camera Replacement: 手順 6、 3の画像 1 Motorola Droid MAXX 2 Rear Camera Replacement: 手順 6、 3の画像 2 Motorola Droid MAXX 2 Rear Camera Replacement: 手順 6、 3の画像 3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Rear Camera Replacement: 手順 7、 1の画像 1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Rear Camera Replacement, Rear Camera: 手順 8、 1の画像 1
    • Peel up orange adhesive that covers the ZIF connector.
  9. Motorola Droid MAXX 2 Rear Camera Replacement: 手順 9、 1の画像 1
    • Use a spudger to lift up the black tab on the ZIF connector.
    • Remove the camera.
終わりに
作成者
6人の作成者と共同で作成されました。
Burke Seggerman
メンバー登録日: 03/18/18
704 ポイント
5のガイドは作成済み
チーム
Baylor, Team S3-G4, Williams Spring 2018 Baylor, Team S3-G4, Williams Spring 2018人のメンバー
BU-WILLIAMS-S18S3G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 334
