はじめに
1. Open Case
2. Remove Battery, SD Card, SIM Card
3. Remove 11 screws around perimeter
4. Peel back sticker from below battery
5. Remove back of phone
6. Remove SIM board from mother board
7. Disconnect three ribbon cables
8. Separate mother board from screen assembly
9. Remove LCD display from screen assembly
10. Separate glass/digitizer from top frame
11. Replace glass/digitizer and re-assemble
必要な工具と部品
Peel back label half way, far enough to expose shields from the motherboard.
There also is a white barcode sticker that will keep the back from coming off.
The spudger tool works great for lifting the edge of the stickers to get a finger hold.
The labels can be easily lifted and replaced without damage.
Separate the glass from the frame.
The two are stuck together with double stick tape. Be careful in prying them apart because the frame appears fragile. The blue plastic opening tools work well.
Slip the new glass/digitizer's two ribbon cables through the holes in the frame and stick the new glass to the frame.
There are also rubber gaskets around each opening in the glass.
11 の人々がこのガイドを完成させました。
3件のガイドコメント
What a royal pain in the a$$... haha it actually was pretty simple, you guys left out that when removing the motherboard from the LCD, the earphone part is stuck together with sticky stuff and has to be pried apart carefully, so not to damage the small cable, I also used a hairdryer to help remove the "lens" from the frame, I salvaged most of the two sided tape but it was stretched out so I had to trim and tuck a little, overall it went back together very simple and everything works great!! Thx for the help!
piece o' cake... thanks for the helpful guide.
Bob Weaver - 返信
Thank you. Helped to have photos. I agree with the other post - you left out the step to pull up the orange cable near the sim card holder (earphone). It does take a bit of wrangling to get it up, but I found that instruction on a video so all is good. The lens I bought came with tools and 3M tape so I didn't have to reuse the old tape from the phone.
