メインコンテンツにスキップ
Motorola Droid Bionic LCD Replacement
必要な工具と部品
  1. Motorola Droid Bionic LCD Replacement, LCD: 手順 1、 1の画像 1
    • Remove the back battery cover.
  2. Motorola Droid Bionic LCD Replacement: 手順 2、 1の画像 1
    • Remove the battery
  3. Motorola Droid Bionic LCD Replacement: 手順 3、 2の画像 1 Motorola Droid Bionic LCD Replacement: 手順 3、 2の画像 2
    • Remove the 11 T4 Torx Screws
    • Next, remove the information sticker.
  4. Motorola Droid Bionic LCD Replacement: 手順 4、 2の画像 1 Motorola Droid Bionic LCD Replacement: 手順 4、 2の画像 2
    • Using a plastic removal tool, work around the edges of the back housing.
    • Lift off the back housing.
  5. Motorola Droid Bionic LCD Replacement: 手順 5、 3の画像 1 Motorola Droid Bionic LCD Replacement: 手順 5、 3の画像 2 Motorola Droid Bionic LCD Replacement: 手順 5、 3の画像 3
    • Remove the two silver T4 screws securing the SIM tray.
    • Carefully lift the SIM tray to disconnect it from the board.
    • Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
    • Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
  6. Motorola Droid Bionic LCD Replacement: 手順 6、 1の画像 1
    • Disconnect the 2 digitizer connectors using a plastic removal tool.
    • Then disconnect the LCD connector
  7. Motorola Droid Bionic LCD Replacement: 手順 7、 2の画像 1 Motorola Droid Bionic LCD Replacement: 手順 7、 2の画像 2
    • The board is now free from all connections. Carefully lift from the top and remove the board.
  8. Motorola Droid Bionic LCD Replacement: 手順 8、 2の画像 1 Motorola Droid Bionic LCD Replacement: 手順 8、 2の画像 2
    • Carefully peel the two flex cables from the back housing of the LCD. Be exceptionally careful during this process, as those flex cables can be easily ripped.
    • With the flex cables out of the way, you can now use a plastic opening tool to carefully pry the old LCD loose and out of the display.
    • If you're installing a new LCD, simply add it now and follow these instructions in reverse to complete the installation.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Taylor
メンバー登録日: 08/30/12
244 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,861
