はじめに
Use this guide to replace your Droid 2's LCD.
必要な工具と部品
Slide the battery cover toward the bottom edge of the phone.
Remove the battery cover from the rear of the phone.
Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
Peel the ribbon off the phone.
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Disconnect the camera button/vibrator connector by prying it straight up off its socket on the speaker board with a spudger.
9 の人々がこのガイドを完成させました。
2件のガイドコメント
Thank you very much for this tutorial. It saved me from buying a new phone! It was scary once the phone was completely disected to think that it had to somehow go back together, but I just followed the steps in reverse. I used t4 for the larger screws as t5 did not seem to fit, but it worked out great. Thanks again.
