メインコンテンツにスキップ
Motorola Defy XT Screen Replacement
必要な工具と部品
  1. Motorola Defy XT Screen Replacement, Battery: 手順 1、 1の画像 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: 手順 2、 1の画像 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: 手順 3、 1の画像 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: 手順 4、 1の画像 1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: 手順 5、 2の画像 1 Motorola Defy XT Screen Replacement, Screen: 手順 5、 2の画像 2
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: 手順 6、 1の画像 1
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: 手順 7、 1の画像 1
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: 手順 8、 1の画像 1
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: 手順 9、 2の画像 1 Motorola Defy XT Screen Replacement: 手順 9、 2の画像 2
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: 手順 10、 2の画像 1 Motorola Defy XT Screen Replacement: 手順 10、 2の画像 2
    • Set the old screen aside and replace it with your new screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Oscar Camacho
メンバー登録日: 04/19/13
89 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G22
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 3,130
