メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
  3. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  4. Insert the opening tool between the battery and the battery holder and wedge the battery out.
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  5. Open the plastic cover with your finger, exposing the SD card.
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
まとめ
2 の人々がこのガイドを完成させました。
Dorian Capps
メンバー登録日: 2013年04月19日
64 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G22
3 メンバー
4のガイドは作成済み
I have replaced the SD card --32 GB---with smaller GB card-- and still my XT phone does not allow movement of APP to this card or saving photo files.
Any other suggestions to get phone to recognize the new card. Cant drag an APP (calculator, eg) to that memory card.
Must I format or seat the card ? or get a different brand ScanDisk 32?
Memorex 8 with Settings reads 7.2 GB total space on this smaller new card.
Gardner
Gardner Neely - 返信
thanks for any guidance on memory card problems Mounting/activating so that I can add files or APPS to that SD card on my Motorola Defy XT 2012 mobile phone.
Gardner Neely -
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 2,148
