メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Defy XT Camera Replacement
必要な工具と部品
  1. Motorola Defy XT Camera Replacement, Camera: 手順 1、 1の画像 1
    • Locate the opening on the corner of the Motorola Defy XT mobile phone.
    • Wedge the Plastic Opening Tool between the back cover and the body of the phone.
    FixBotに聞いてみる
  2. Motorola Defy XT Camera Replacement: 手順 2、 1の画像 1
    • Once wedged in the opening, gently pry around the phone until back cover lifts off.
    FixBotに聞いてみる
  3. Motorola Defy XT Camera Replacement: 手順 3、 1の画像 1
    • Remove the back cover and locate the battery.
    • Insert the opening tool beneath the battery and lightly push upward.
    FixBotに聞いてみる
  4. Motorola Defy XT Camera Replacement: 手順 4、 1の画像 1
    • Locate the SD card beneath the plastic cover in the corner.
    • Use a Plastic Opening Tool to hook the edge of the SD card
    FixBotに聞いてみる
  5. Motorola Defy XT Camera Replacement: 手順 5、 1の画像 1
    • Push the SD card straight out.
    FixBotに聞いてみる
  6. Motorola Defy XT Camera Replacement: 手順 6、 1の画像 1
    • Use the T4 Torque Driver to remove all 6 of the 3mm diameter screws on the outside edges of the phone.
    FixBotに聞いてみる
  7. Motorola Defy XT Camera Replacement: 手順 7、 1の画像 1
    • Wedge the Plastic Opening Tool under the inner side of the volume buttons.
    • Pop the volume buttons out of the phone.
    FixBotに聞いてみる
  8. Motorola Defy XT Camera Replacement: 手順 8、 1の画像 1
    • Locate the base of the motherboard.
    • Slide the Plastic Opening Tool along the base of the motherboard to separate it from the phone.
    • Gently guide the two pieces apart with upward motion.
    • Caution: Do not damage the ribbon that is holding both pieces
    FixBotに聞いてみる
  9. Motorola Defy XT Camera Replacement: 手順 9、 1の画像 1
    • Disconnect the ribbon from the frame.
    • Remove the screen.
    FixBotに聞いてみる
  10. Motorola Defy XT Camera Replacement: 手順 10、 1の画像 1
    • Flip the mother board over.
    • Locate the base of the ribbon cable.
    • Pull straight outward using the Plastic Opening Tool.
    • Disconnect the ribbon cable connecting the display to the logic board
    FixBotに聞いてみる
  11. Motorola Defy XT Camera Replacement: 手順 11、 1の画像 1
    • Pull the two halves of the device apart to disconnect the second (wider) ribbon connector.
    • Note: The ribbon connector is bonded to the logic board with adhesive, simply pull it to remove it completely.
    FixBotに聞いてみる
  12. Motorola Defy XT Camera Replacement: 手順 12、 1の画像 1
    • Use the Plastic Opening Tool to disconnect the camera from the logic board.
    FixBotに聞いてみる
終わりに
作成者
6人の作成者と共同で作成されました。
Mustapha Nadri
メンバー登録日: 04/19/13
1 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 2-22, Maness Spring 2013 Cal Poly, Team 2-22, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G22
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 48
今までの合計 1,157
