はじめに
This guide will go through the steps of replacing the speaker for the Motorola MB525 starting from the tear down of the phone to replacement of the speaker itself.
  1. Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up. Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Use a plastic opening tool to pry the battery out of the phone.
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Unscrew the two silver screws located at the top of the back of the phone.
    • Unscrew the two silver screws located at the top of the back of the phone.
  6. Use a plastic opening tool to gently pry the midframe from the rest of the phone.
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  7. Use metal spudger to pry off the middle yellow flap carefully. Use metal spudger to pry off the middle yellow flap carefully.
    • Use metal spudger to pry off the middle yellow flap carefully.
  8. Use tweezers again to pry off the second yellow flap carefully. Use tweezers again to pry off the second yellow flap carefully. Use tweezers again to pry off the second yellow flap carefully.
    • Use tweezers again to pry off the second yellow flap carefully.
  9. The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  10. Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown. The speaker is glued to its position, thus you will have to glue the new one back on.
    • Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown.
    • The speaker is glued to its position, thus you will have to glue the new one back on.
    • The speaker must be pried off carefully. It is very delicate.
まとめ
Andres
メンバー登録日: 2014年10月08日
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 14-2, Leahy Fall 2014 USF Tampa, Team 14-2, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S14G2
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 485
