メインコンテンツにスキップ
Motorola DROID RAZR MAXX Camera Cover Replacement
必要な工具と部品
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 手順 1、 2の画像 1 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: 手順 1、 2の画像 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: 手順 2、 2の画像 1 Motorola DROID RAZR MAXX Camera Cover Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: 手順 3、 3の画像 1 Motorola DROID RAZR MAXX Camera Cover Replacement: 手順 3、 3の画像 2 Motorola DROID RAZR MAXX Camera Cover Replacement: 手順 3、 3の画像 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: 手順 4、 1の画像 1
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Govind
メンバー登録日: 10/08/14
130 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 14-6, Leahy Fall 2014 USF Tampa, Team 14-6, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S14G6
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 11
今までの合計 699
