はじめに
Did you rock too hard for your audio jack? Use this guide to replace a damaged or broken audio jack on the Motorola Cliq. You will need to be ready to handle 4.0 mm screws and other small parts.
パーツ
パーツは指定されていません。
Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
Turn the phone over and slide out the keyboard.
Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
