メインコンテンツにスキップ
Motorola California Mobile Phone Antenna Replacement
必要な工具と部品
  1. Motorola California Mobile Phone Antenna Replacement, Antenna: 手順 1、 1の画像 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Antenna Replacement: 手順 2、 1の画像 1
    • Insert the Phillips 00 screwdriver into the holes that connect the key pad guard to the rear casing in the plastic rod.
    • The following step may require a substantial amount of force.
    • Use the screwdriver to push the rods towards each other until they click out of their locked positions.
  3. Motorola California Mobile Phone Antenna Replacement: 手順 3、 1の画像 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Push the clips outward while simultaneously lifting the rear casing and keyguard away from the front casing.
  4. Motorola California Mobile Phone Antenna Replacement: 手順 4、 1の画像 1
    • Locate and unplug the black component of the current antenna from the motherboard.
    • Under the black component there should be a blue component.
    • Unscrew the blue component in order to free the antenna.
  5. Motorola California Mobile Phone Antenna Replacement: 手順 5、 1の画像 1
    • Slide the antenna out of the green tubing.
    • Slide the green tubing out of its hole.
  6. Motorola California Mobile Phone Antenna Replacement: 手順 6、 1の画像 1
    • Insert the new green tubing into the corresponding slot.
  7. Motorola California Mobile Phone Antenna Replacement: 手順 7、 1の画像 1
    • Insert the new antenna into the green tubing.
  8. Motorola California Mobile Phone Antenna Replacement: 手順 8、 1の画像 1
    • Screw the blue piece of the antenna into the threaded hole on the motherboard until it is tight.
  9. Motorola California Mobile Phone Antenna Replacement: 手順 9、 1の画像 1
    • Align the protruding wire on the black component with the corresponding hole on the motherboard.
    • Push the wire into the hole.
  10. Motorola California Mobile Phone Antenna Replacement: 手順 10、 1の画像 1
    • Reverse the instructions from Step 2 to re-install the keypad guard and rear casing onto the device.
  11. Motorola California Mobile Phone Antenna Replacement: 手順 11、 1の画像 1
    • Push down on the antenna guard until it clicks into place.
終わりに
作成者
13人の作成者と共同で作成されました。
Andrew Lam
メンバー登録日: 04/17/12
53 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G46
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 19
今までの合計 1,919
