メインコンテンツにスキップ
Motorola C261 Front Speaker Replacement
必要な工具と部品
  1. Motorola C261 Front Speaker Replacement, Place Phone: 手順 1、 1の画像 1
    • Place the phone with the screen facedown on a flat surface.
  2. Motorola C261 Front Speaker Replacement, Latch and Back Cover: 手順 2、 2の画像 1 Motorola C261 Front Speaker Replacement, Latch and Back Cover: 手順 2、 2の画像 2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
  3. Motorola C261 Front Speaker Replacement, Remove Battery: 手順 3、 2の画像 1 Motorola C261 Front Speaker Replacement, Remove Battery: 手順 3、 2の画像 2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
  4. Motorola C261 Front Speaker Replacement, Clips: 手順 4、 2の画像 1 Motorola C261 Front Speaker Replacement, Clips: 手順 4、 2の画像 2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
  5. Motorola C261 Front Speaker Replacement, Button Circuit Board: 手順 5、 2の画像 1 Motorola C261 Front Speaker Replacement, Button Circuit Board: 手順 5、 2の画像 2
    • The circuit board for the buttons is now free to be removed and replaced.
  6. Motorola C261 Front Speaker Replacement, Front Speaker: 手順 6、 2の画像 1 Motorola C261 Front Speaker Replacement, Front Speaker: 手順 6、 2の画像 2
    • Pry under the display screen, around each edge until it comes loose from the circuit board.
    • You are removing the black plastic piece that holds the button circuit board. The piece has an aluminum frame around it. The two pieces will be removed together and don't need to be separated.
  7. Motorola C261 Front Speaker Replacement, Lifting Framework: 手順 7、 1の画像 1
    • Gently remove the plastic and metal framework of the phone by picking it up.
  8. Motorola C261 Front Speaker Replacement: 手順 8、 2の画像 1 Motorola C261 Front Speaker Replacement: 手順 8、 2の画像 2
    • The front speaker should be contained in the framework that you just removed. Remove the speaker by lifting it out.
    • Use a tool that isn't sharp to poke it out should the first method prove too difficult.
終わりに
作成者
2人の作成者と共同で作成されました。
Jason
メンバー登録日: 10/23/14
305 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-6, Lauer Fall 2014 Michigan Tech, Team 1-6, Lauer Fall 2014人のメンバー
MTU-LAUER-F14S1G6
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 133
