1. Place the phone with the screen facedown on a flat surface.
    • Place the phone with the screen facedown on a flat surface.
  2. Pinch the latch upwards towards the top of the phone.
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
    • The circuit board for the buttons is now free to be removed and replaced.
    • Pry under the display screen, around each edge until it comes loose from the circuit board.
      • You are removing the black plastic piece that holds the button circuit board. The piece has an aluminum frame around it. The two pieces will be removed together and don't need to be separated.
    • Gently remove the plastic and metal framework of the phone by picking it up.
    • The front speaker should be contained in the framework that you just removed. Remove the speaker by lifting it out.
    • Use a tool that isn't sharp to poke it out should the first method prove too difficult.
まとめ
Jason
メンバー登録日: 2014年10月23日
304 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-6, Lauer Fall 2014 Michigan Tech, Team 1-6, Lauer Fall 2014人のメンバー
MTU-LAUER-F14S1G6
3 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
