メインコンテンツにスキップ
Motorola C261 Button Circuit Board Replacement
必要な工具と部品
  1. Motorola C261 Button Circuit Board Replacement, Place Phone: 手順 1、 1の画像 1
    • Place the phone with the screen facedown on a flat surface.
  2. Motorola C261 Button Circuit Board Replacement, Latch and Back Cover: 手順 2、 2の画像 1 Motorola C261 Button Circuit Board Replacement, Latch and Back Cover: 手順 2、 2の画像 2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
  3. Motorola C261 Button Circuit Board Replacement, Remove Battery: 手順 3、 2の画像 1 Motorola C261 Button Circuit Board Replacement, Remove Battery: 手順 3、 2の画像 2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
  4. Motorola C261 Button Circuit Board Replacement, Screws in Rear Housing: 手順 4、 1の画像 1
    • Remove the four 8.5 mm screws from under the battery cover with a T4 Torx screwdriver.
    • Remove the two 8.5 mm screws from the top of the phone with a T4 Torx screwdriver.
  5. Motorola C261 Button Circuit Board Replacement, Rear Housing: 手順 5、 2の画像 1 Motorola C261 Button Circuit Board Replacement, Rear Housing: 手順 5、 2の画像 2
    • Using the plastic pry tool remove the rear housing from the rest of the phone. You may have to pry around all edges of the phone, not just the edge shown.
    • When you remove the rear housing, the rubber cover for the headphone jack/charge port may fall out. If not, remove it.
  6. Motorola C261 Button Circuit Board Replacement, Spacers: 手順 6、 2の画像 1 Motorola C261 Button Circuit Board Replacement, Spacers: 手順 6、 2の画像 2
    • Remove the small black circular rubber spacer.
    • Remove the white rubber spacer.
    • These pieces are small and easy to lose, especially the black one. Set them somewhere safe!
  7. Motorola C261 Button Circuit Board Replacement, Motherboard and Front Housing: 手順 7、 2の画像 1 Motorola C261 Button Circuit Board Replacement, Motherboard and Front Housing: 手順 7、 2の画像 2
    • Gently remove the motherboard assembly from the front housing.
    • Now, the front housing is free to be replaced, as well as the cosmetic keypad.
  8. Motorola C261 Button Circuit Board Replacement, Clips: 手順 8、 2の画像 1 Motorola C261 Button Circuit Board Replacement, Clips: 手順 8、 2の画像 2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
  9. Motorola C261 Button Circuit Board Replacement, Button Circuit Board: 手順 9、 2の画像 1 Motorola C261 Button Circuit Board Replacement, Button Circuit Board: 手順 9、 2の画像 2
    • The circuit board for the buttons is now free to be removed and replaced.
終わりに
作成者
2人の作成者と共同で作成されました。
Jason
メンバー登録日: 10/23/14
305 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-6, Lauer Fall 2014 Michigan Tech, Team 1-6, Lauer Fall 2014人のメンバー
MTU-LAUER-F14S1G6
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 144
