メインコンテンツにスキップ
Motorola C168 Screen Replacement
必要な工具と部品
  1. Motorola C168 Screen Replacement, Battery: 手順 1、 2の画像 1 Motorola C168 Screen Replacement, Battery: 手順 1、 2の画像 2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Screen Replacement: 手順 2、 2の画像 1 Motorola C168 Screen Replacement: 手順 2、 2の画像 2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Screen Replacement, SIM Card: 手順 3、 2の画像 1 Motorola C168 Screen Replacement, SIM Card: 手順 3、 2の画像 2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Screen Replacement, Front Panel: 手順 4、 2の画像 1 Motorola C168 Screen Replacement, Front Panel: 手順 4、 2の画像 2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Screen Replacement: 手順 5、 2の画像 1 Motorola C168 Screen Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
  6. Motorola C168 Screen Replacement, Screen: 手順 6、 2の画像 1 Motorola C168 Screen Replacement, Screen: 手順 6、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Place the phone on its back.
    • Insert the spudger at the bottom of the phone, between the phone's frame and the circuit board.
    • Remove the circuit board from the frame.
    • Removing the board takes more force than you would expect.
  7. Motorola C168 Screen Replacement: 手順 7、 2の画像 1 Motorola C168 Screen Replacement: 手順 7、 2の画像 2
    • Bend the screen clamps outward so they are no longer underneath the circuit board.
    • Pull the screen encasing away from the circuit board.
    • Caution: The screen-to-phone interface will still be connected.
  8. Motorola C168 Screen Replacement: 手順 8、 2の画像 1 Motorola C168 Screen Replacement: 手順 8、 2の画像 2
    • Unplug the screen-to-phone interface.
    • Remove the screen from its encasing by pushing it out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Christopher Wu
メンバー登録日: 04/17/12
37 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-40, Regan Spring 2012 Cal Poly, Team 12-40, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S12G40
4 メンバー
8のガイドは作成済み
2 件のコメント
motorola c168 network not working problem. how to repair network problem?
sattar - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 19
今までの合計 1,379
