必要な工具と部品
Begin by flipping your phone over so that the back cover is facing up.
Apply force to the back cover and simultaneously slide the cover down.
Unhook the antenna by releasing the two hooks, one on each side of the phone.
Detach the antenna from the back of the circuit board
This small black rubber cover may detach.
Unhook the 10 clips holding the metal screen cover in place and pull up to detach it from the logic board.
There are four clips at the top, two along each side, and two clips at the bottom of the metal cover.
