Begin by flipping your phone over so that the back cover is facing up.
Apply force to the back cover and simultaneously slide the cover down.
Note: Applying pressure on the ridges will make it easier to remove the cover.
Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
Release a total of six hooks from the sides and top to free the phone into two halves.
Use plastic opening tools to free the circuit board from the case.
There are two hooks (one on each side) holding the circuit board into the case.
Then grip the circuit board and lift to remove the circuit board from the case.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
