メインコンテンツにスキップ
Motorola C139 Rear Casing Replacement
必要な工具と部品
  1. Motorola C139 Rear Casing Replacement, Battery: 手順 1、 3の画像 1 Motorola C139 Rear Casing Replacement, Battery: 手順 1、 3の画像 2 Motorola C139 Rear Casing Replacement, Battery: 手順 1、 3の画像 3
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Motorola C139 Rear Casing Replacement: 手順 2、 3の画像 1 Motorola C139 Rear Casing Replacement: 手順 2、 3の画像 2 Motorola C139 Rear Casing Replacement: 手順 2、 3の画像 3
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Motorola C139 Rear Casing Replacement, Rear Casing: 手順 3、 3の画像 1 Motorola C139 Rear Casing Replacement, Rear Casing: 手順 3、 3の画像 2 Motorola C139 Rear Casing Replacement, Rear Casing: 手順 3、 3の画像 3
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61 mm in diameter.
  4. Motorola C139 Rear Casing Replacement: 手順 4、 3の画像 1 Motorola C139 Rear Casing Replacement: 手順 4、 3の画像 2 Motorola C139 Rear Casing Replacement: 手順 4、 3の画像 3
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side.
  5. Motorola C139 Rear Casing Replacement: 手順 5、 3の画像 1 Motorola C139 Rear Casing Replacement: 手順 5、 3の画像 2 Motorola C139 Rear Casing Replacement: 手順 5、 3の画像 3
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
    • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
  6. Motorola C139 Rear Casing Replacement: 手順 6、 3の画像 1 Motorola C139 Rear Casing Replacement: 手順 6、 3の画像 2 Motorola C139 Rear Casing Replacement: 手順 6、 3の画像 3
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
  7. Motorola C139 Rear Casing Replacement: 手順 7、 3の画像 1 Motorola C139 Rear Casing Replacement: 手順 7、 3の画像 2 Motorola C139 Rear Casing Replacement: 手順 7、 3の画像 3
    • Use plastic opening tools to free the circuit board from the case.
    • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case.
終わりに
作成者
6人の作成者と共同で作成されました。
Christopher Stubbs
メンバー登録日: 03/09/12
56 ポイント
4のガイドは作成済み
チーム
Clemson, Team 2-2, Benson Spring 2012 Clemson, Team 2-2, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S2G2
3 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 950
