Begin by flipping your phone over so that the back cover is facing up.
Apply force to the back cover and simultaneously slide the cover down.
Note: Applying pressure on the ridges will make it easier to remove the cover.
Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
Gently slide the SIM card out and lift to remove it from the phone.
Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
Release a total of six hooks from the sides and top to free the phone into two halves.
Use plastic opening tools to free the circuit board from the case.
There are two hooks (one on each side) holding the circuit board into the case.
Then grip the circuit board and lift to remove the circuit board from the case.
Unhook the antenna by releasing the two hooks, one on each side of the phone.
Detach the antenna from the back of the circuit board
This small black rubber cover may detach.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
