はじめに
The cameras of the Atrix HD are protected by the housing of the phone, but they can be damaged by exposure to moisture, impact, or scratches. If your photo quality is suffering it may be time to replace the affected camera. With just two tools, you can be back to taking high-quality photos in no time.
必要な工具と部品
Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
Continue working around the edge of the phone using the plastic opening tool.
When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
The adhesive strips may stay on the back cover or the battery.
Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
Begin by removing the 10 Torx T5 motherboard baseplate screws
The back chassis can now be removed.
Remove the three Torx T5 screws that locks the front facing camera to the motherboard.
Use the plastic opening tool to lift the ribbon cable from the motherboard.
3 の人々がこのガイドを完成させました。
