メインコンテンツにスキップ
Motorola Atrix HD Battery Replacement
必要な工具と部品
  1. Motorola Atrix HD Battery Replacement, Battery: 手順 1、 3の画像 1 Motorola Atrix HD Battery Replacement, Battery: 手順 1、 3の画像 2 Motorola Atrix HD Battery Replacement, Battery: 手順 1、 3の画像 3
    • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
    • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
    • Continue working around the edge of the phone using the plastic opening tool.
    • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
  2. Motorola Atrix HD Battery Replacement: 手順 2、 1の画像 1
    • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
  3. Motorola Atrix HD Battery Replacement: 手順 3、 3の画像 1 Motorola Atrix HD Battery Replacement: 手順 3、 3の画像 2 Motorola Atrix HD Battery Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the red rubber screw cover with a pair of tweezers
  4. Motorola Atrix HD Battery Replacement: 手順 4、 2の画像 1 Motorola Atrix HD Battery Replacement: 手順 4、 2の画像 2
    • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
  5. Motorola Atrix HD Battery Replacement: 手順 5、 1の画像 1
    • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
  6. Motorola Atrix HD Battery Replacement: 手順 6、 3の画像 1 Motorola Atrix HD Battery Replacement: 手順 6、 3の画像 2 Motorola Atrix HD Battery Replacement: 手順 6、 3の画像 3
    • Use the plastic opening tool around the edges to loosen the battery.
    • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
  7. Motorola Atrix HD Battery Replacement: 手順 7、 1の画像 1
    • The battery may now be removed.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Bradley Hinckley
メンバー登録日: 10/28/15
561 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-8, Miles Fall 2015 UMass Dartmouth, Team 1-8, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G8
3 メンバー
10のガイドは作成済み
コメント 1 件
How do you calibrate it then? Lights up green dot, charges, won't work! Multi tester shows full power.
jvandeputte - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 16
今までの合計 3,247
