メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Motorola Atrix 4G Antenna Replacement
必要な工具と部品
  1. Motorola Atrix 4G Antenna Replacement, Battery: 手順 1、 1の画像 1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Antenna Replacement: 手順 2、 2の画像 1 Motorola Atrix 4G Antenna Replacement: 手順 2、 2の画像 2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Antenna Replacement, Antenna: 手順 3、 3の画像 1 Motorola Atrix 4G Antenna Replacement, Antenna: 手順 3、 3の画像 2 Motorola Atrix 4G Antenna Replacement, Antenna: 手順 3、 3の画像 3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Antenna Replacement: 手順 4、 2の画像 1 Motorola Atrix 4G Antenna Replacement: 手順 4、 2の画像 2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Antenna Replacement: 手順 5、 2の画像 1 Motorola Atrix 4G Antenna Replacement: 手順 5、 2の画像 2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Antenna Replacement: 手順 6、 1の画像 1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Antenna Replacement: 手順 7、 1の画像 1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Antenna Replacement: 手順 8、 1の画像 1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
終わりに
5 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Derek Walker
メンバー登録日: 04/19/12
297 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-42, Regan Spring 2012 Cal Poly, Team 9-42, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G42
6 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 5,406
