メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This process involves first removing the battery, outer case, and motherboard. After, the display can be removed from the motherboard.
パーツ
パーツは指定されていません。
  1. Hold the phone and pull the back latch down towards the bottom. Remove the back panel by releasing the latch and lifting from the top.
    • Hold the phone and pull the back latch down towards the bottom.
    • Remove the back panel by releasing the latch and lifting from the top.
  2. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up.
    • Remove the battery by pushing the bottom end towards the top, then lifting up.
  3. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  4. Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver. Once the screws are removed, simply lift the back panel off Once the screws are removed, simply lift the back panel off
    • Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
    • Once the screws are removed, simply lift the back panel off
  5. Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out. Remove the motherboard by lifting it up and out.
    • Remove the motherboard by lifting it up and out.
  6. Use tweezers to pry off the four clasps that hold the display in place.
    • Use tweezers to pry off the four clasps that hold the display in place.
  7. Remove the display. Remove the display.
    • Remove the display.
終わりに
Eric Dazet
メンバー登録日: 2012年04月10日
352 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 6-21, Amido Spring 2012 Cal Poly, Team 6-21, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S6G21
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 657
