メインコンテンツにスキップ
Motherboard by why! Replace W253EU
必要な工具と部品
  1. Motherboard by why! Replace W253EU, Battery from why! Remove W253EU: 手順 1、 3の画像 1 Motherboard by why! Replace W253EU, Battery from why! Remove W253EU: 手順 1、 3の画像 2 Motherboard by why! Replace W253EU, Battery from why! Remove W253EU: 手順 1、 3の画像 3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Motherboard by why! Replace W253EU, Access to RAM and CPU from why! W253EU: 手順 2、 2の画像 1 Motherboard by why! Replace W253EU, Access to RAM and CPU from why! W253EU: 手順 2、 2の画像 2
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Motherboard by why! Replace W253EU: 手順 3、 3の画像 1 Motherboard by why! Replace W253EU: 手順 3、 3の画像 2 Motherboard by why! Replace W253EU: 手順 3、 3の画像 3
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Motherboard by why! Replace W253EU: 手順 4、 1の画像 1
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
  5. Motherboard by why! Replace W253EU, CD / DVD RW drive: 手順 5、 2の画像 1 Motherboard by why! Replace W253EU, CD / DVD RW drive: 手順 5、 2の画像 2
    • Use a Phillips # 1 screwdriver to screw that holds the CD / DVD drive in place.
  6. Motherboard by why! Replace W253EU: 手順 6、 3の画像 1 Motherboard by why! Replace W253EU: 手順 6、 3の画像 2 Motherboard by why! Replace W253EU: 手順 6、 3の画像 3
    • Pull the CD / DVD drive carefully out
  7. Motherboard by why! Replace W253EU, Keyboard: 手順 7、 3の画像 1 Motherboard by why! Replace W253EU, Keyboard: 手順 7、 3の画像 2 Motherboard by why! Replace W253EU, Keyboard: 手順 7、 3の画像 3
    • Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
    • Insert a standard screwdriver into the slot in the cover above the keyboard.
    • Lift the cover with the usual care.
  8. Motherboard by why! Replace W253EU: 手順 8、 3の画像 1 Motherboard by why! Replace W253EU: 手順 8、 3の画像 2 Motherboard by why! Replace W253EU: 手順 8、 3の画像 3
    • Use a Phillips # 1 screwdriver to remove the four screws securing the keyboard in the upper part.
  9. Motherboard by why! Replace W253EU: 手順 9、 2の画像 1 Motherboard by why! Replace W253EU: 手順 9、 2の画像 2
    • Turn the keyboard towards the screen.
    • Carefully remove the connection cable in the direction of the plug axis.
  10. Motherboard by why! Replace W253EU, motherboard: 手順 10、 2の画像 1 Motherboard by why! Replace W253EU, motherboard: 手順 10、 2の画像 2
    • Disconnect plug A.
    • Disconnect plug B.
  11. Motherboard by why! Replace W253EU: 手順 11、 3の画像 1 Motherboard by why! Replace W253EU: 手順 11、 3の画像 2 Motherboard by why! Replace W253EU: 手順 11、 3の画像 3
    • Using the Phillips # 1 screwdriver, remove the 16 screws that secure the cover.
  12. Motherboard by why! Replace W253EU: 手順 12、 3の画像 1 Motherboard by why! Replace W253EU: 手順 12、 3の画像 2 Motherboard by why! Replace W253EU: 手順 12、 3の画像 3
    • Using a Phillips #1 screwdriver, remove all 16 screws that secure the entire cover.
  13. Motherboard by why! Replace W253EU: 手順 13、 3の画像 1 Motherboard by why! Replace W253EU: 手順 13、 3の画像 2 Motherboard by why! Replace W253EU: 手順 13、 3の画像 3
  14. Motherboard by why! Replace W253EU: 手順 14、 3の画像 1 Motherboard by why! Replace W253EU: 手順 14、 3の画像 2 Motherboard by why! Replace W253EU: 手順 14、 3の画像 3
  15. Motherboard by why! Replace W253EU: 手順 15、 2の画像 1 Motherboard by why! Replace W253EU: 手順 15、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the other screw located on the back.
    • Remove the connector for the touchpad.
  16. Motherboard by why! Replace W253EU: 手順 16、 3の画像 1 Motherboard by why! Replace W253EU: 手順 16、 3の画像 2 Motherboard by why! Replace W253EU: 手順 16、 3の画像 3
    • To remove the keyboard frame, start with the upper part on the right. (Visual access to the clips through the opening of the CD/DVD drive) by inserting a small normal screwdriver or better a small guitar pick
    • Then continue with the lower part.
  17. Motherboard by why! Replace W253EU: 手順 17、 3の画像 1 Motherboard by why! Replace W253EU: 手順 17、 3の画像 2 Motherboard by why! Replace W253EU: 手順 17、 3の画像 3
    • Proceed with the removal of the keyboard bezel in the clockwise direction.
    • Remove the keyboard frame and the motherboard appears.
  18. Motherboard by why! Replace W253EU: 手順 18、 2の画像 1 Motherboard by why! Replace W253EU: 手順 18、 2の画像 2
    • Unplug the main connector.
    • Unplug the small connector in the middle.
  19. Motherboard by why! Replace W253EU: 手順 19、 3の画像 1 Motherboard by why! Replace W253EU: 手順 19、 3の画像 2 Motherboard by why! Replace W253EU: 手順 19、 3の画像 3
    • Turn the computer over and unplug the connector near the processor (CPU).
    • Remove the other connector that is immediately to the right of it.
    • Using a Philips #1 screwdriver, remove the 2 mounting screws of the Wi-Fi chipset.
  20. Motherboard by why! Replace W253EU: 手順 20、 3の画像 1 Motherboard by why! Replace W253EU: 手順 20、 3の画像 2 Motherboard by why! Replace W253EU: 手順 20、 3の画像 3
    • Unplug the plug that is positioned in the back
    • Disconnect the small connector that is right next to the first connector.
    • With a Philips #1 screwdriver, remove the screws outlined in red.
  21. Motherboard by why! Replace W253EU: 手順 21、 3の画像 1 Motherboard by why! Replace W253EU: 手順 21、 3の画像 2 Motherboard by why! Replace W253EU: 手順 21、 3の画像 3
    • Using a Philips #1 screwdriver, remove the 10 mounting screws from the motherboard.
    • Disconnect the small connector that is located in the front.
    • With a Philips #1 screwdriver, remove the 2 screws that are crosswise and marked with blue circles.
    • Take out the motherboard.
終わりに
For reassembly, follow the instructions in reverse order.
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Felice Suglia
メンバー登録日: 06/15/13
31,100 ポイント
264のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 438
