必要な工具と部品
Turn off the computer.
Take the slide unlocked into position, remove the battery.
Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
Use a Phillips # 1 screwdriver to screw that holds the CD / DVD drive in place.
Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
Insert a standard screwdriver into the slot in the cover above the keyboard.
Lift the cover with the usual care.
For reassembly, follow the instructions in reverse order.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
