メインコンテンツにスキップ
Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side)
必要な工具と部品
  1. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side), Back Cover: 手順 1、 1の画像 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 2、 1の画像 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 3、 2の画像 1 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 3、 2の画像 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side), Cassette Player (Left Side): 手順 4、 1の画像 1
    • Remove the following 6 screws:
    • Four 25 mm Phillips
    • Two 2.5 mm Flathead
  5. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 5、 1の画像 1
    • Remove the small steel plate on the right-hand side.
  6. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 6、 1の画像 1
    • Move the brass plate with attached pneumatic cylinder on the left-hand side.
    • Detach the plate at the pneumatic cylinder and leave the plate attached to the torsional spring.
  7. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 7、 3の画像 1 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 7、 3の画像 2 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 7、 3の画像 3
    • Stand the unit up and press eject to open the door on the cassette player.
    • Gripping the cassette player from the back, lift upwards on the door to unclip it from the bar around which it rotates. This may take some effort.
  8. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 8、 1の画像 1
    • Remove the 5 mm Phillips screw holding the blue and yellow wires in place.
  9. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 9、 3の画像 1 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 9、 3の画像 2 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 9、 3の画像 3
    • Unsolder the red and white wires leading from the cassette player unit.
  10. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 10、 1の画像 1
    • Unplug the grey wire leading from the cassette player.
  11. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 手順 11、 1の画像 1
    • Remove the cassette player.
終わりに
作成者
2人の作成者と共同で作成されました。
Dustin Platt
メンバー登録日: 04/01/15
931 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S12G5
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 218
