メインコンテンツにスキップ
Monster Soundstage S2 Rear Panel Connectors Replacement
必要な工具と部品
  1. Monster Soundstage S2 Rear Panel Connectors Replacement, Speaker Grille: 手順 1、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement, Speaker Grille: 手順 1、 2の画像 2
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 2、 3の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 2、 3の画像 2 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 2、 3の画像 3
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 3、 1の画像 1
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 4、 3の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 4、 3の画像 2 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 4、 3の画像 3
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 5、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 5、 2の画像 2
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 6、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 6、 2の画像 2
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 7、 3の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 7、 3の画像 2 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 7、 3の画像 3
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 8、 1の画像 1
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Rear Panel Connectors Replacement, Front Speakers: 手順 9、 3の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement, Front Speakers: 手順 9、 3の画像 2 Monster Soundstage S2 Rear Panel Connectors Replacement, Front Speakers: 手順 9、 3の画像 3
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 10、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 10、 2の画像 2
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 11、 3の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 11、 3の画像 2 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 11、 3の画像 3
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
  12. Monster Soundstage S2 Rear Panel Connectors Replacement, Front Panel: 手順 12、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement, Front Panel: 手順 12、 2の画像 2
    • Identify the eight screws around the border of the front panel.
    • Using the TR 10 driver, remove the two 8mm screws.
    • Using the TR 10 driver, remove the six 12mm screws.
  13. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 13、 1の画像 1
    • Use a 5 mm hex driver to extend the TR 10 driver. This allows the driver to access screws with deeper countersinks.
  14. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 14、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 14、 2の画像 2
    • Identify the remaining four screws in the front panel.
    • Use the extended driver from the previous step to remove the four 12mm TR 10 screws.
  15. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 15、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 15、 2の画像 2
    • Gently pull the front panel away from the back panel.
    • There are wires that connect the front and back panels. The two sides can be safely folded away from each other and laid flat on the table.
    • Remove the white sound dampening material from the speaker. Note the location of the material and set aside.
  16. Monster Soundstage S2 Rear Panel Connectors Replacement, Rear Panel Connectors: 手順 16、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement, Rear Panel Connectors: 手順 16、 2の画像 2
    • Use a TR 10 driver to remove the two 10mm screws securing the connector housing.
    • Remove the housing from the rear panel.
    • Do not stress or tear the cables that connect this part to the logic board.
  17. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 17、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 17、 2の画像 2
    • With the housing free from the speaker, the two daughterboards can be seen in the housing.
    • Gently remove both boards from the housing.
    • Be aware of the fragile ribbon connector that runs between the boards, as well as the cords that run to the logic board.
  18. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 18、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 18、 2の画像 2
    • Unplug the ribbon cable that connects the daughterboards from the top board. Leave the cable connected to the bottom board.
    • In order to remove the ribbon cable, gently pull the brown retention mechanism away from the connector. The ribbon cable can then be freely removed.
  19. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 19、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 19、 2の画像 2
    • Gently unplug the red power connector from the top daughterboard.
    • Note the correct orientation of this connector for reassembly.
  20. Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 20、 2の画像 1 Monster Soundstage S2 Rear Panel Connectors Replacement: 手順 20、 2の画像 2
    • Gently pull out the large ribbon cable from the bottom logic board. Grasp the cable as close to the connector as possible and pull it straight away from the board.
    • There is no retention mechanism on this connector.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Shaw Hughes
メンバー登録日: 01/30/17
831 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 21-5, Maness Winter 2017 Cal Poly, Team 21-5, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S21G5
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 225
