はじめに
This guide will aid you in the replacement of the logic board in the speaker.
必要な工具と部品
Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
After removing grille, you will see the speakers.
Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
Identify the eight screws around the border of the front panel.
Using the TR 10 driver, remove the two 8mm screws.
Using the TR 10 driver, remove the six 12mm screws.
Unplug the rear white connector from the logic board.
Unplug the rear red connector beside the white one.
3 の人々がこのガイドを完成させました。
2 件のコメント
Monster Soundstage circuit board supplier?
@shughe11 Monster Soundstage circuit board supplier?
