はじめに
This guide can be used to replace the front speakers of Monster Soundstage S2 speaker.
必要な工具と部品
Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
After removing grille, you will see the speakers.
Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
ある他の人がこのガイドを完成しました。
コメント 1 件
Does anybody know what size driver the rear woofer is and resistance, would like to repair an s3 for a friend in cuba who received a used one as a gift
Matt Gould - 返信
