はじめに
This guide will help you remove the front panel of the speaker. Most likely, this part will not need to be replaced due to damage, but it must be removed before other parts.
必要な工具と部品
Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
After removing grille, you will see the speakers.
Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
Identify the eight screws around the border of the front panel.
Using the TR 10 driver, remove the two 8mm screws.
Using the TR 10 driver, remove the six 12mm screws.
2 の人々がこのガイドを完成させました。
