メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Momentary Switch Replacement
必要な工具と部品
  1. Momentary Switch Replacement, Turn off power: 手順 1、 3の画像 1 Momentary Switch Replacement, Turn off power: 手順 1、 3の画像 2 Momentary Switch Replacement, Turn off power: 手順 1、 3の画像 3
    • Find your Breaker Panel.
    • Identify the breaker to turn off.
    • There'll typically be a table listing the rooms corresponding to breakers.
    • Turn off the breaker.
    • Press the switch to ensure that the power is actually off (p. ex. the lights don't turn on).
  2. Momentary Switch Replacement, Remove the old switch cover: 手順 3、 3の画像 1 Momentary Switch Replacement, Remove the old switch cover: 手順 3、 3の画像 2 Momentary Switch Replacement, Remove the old switch cover: 手順 3、 3の画像 3
    • Remove the switch cover by jamming a flat head screwdriver into the gap between the outer frame and the switch cover.
    • Some manufacturers, like Busch-Jaeger have an extra frame beneath the switch cover, so you'll have to remove that as well.
    • Remove the frame
    • If you can't remove the frame because there's a wall socket on the same frame, take a look at this guide, on how to remove the cover of a wall outlet.
  3. Momentary Switch Replacement, Remove the old switch: 手順 4、 1の画像 1
    • Loosen the holding claws by turning the two screws.
    • If your switch is mounted inside a cavity wall box you can remove it by loosening the two screws around the perimeter and turning the switch until the two keyholes line up.
  4. Momentary Switch Replacement, Determine voltage absence: 手順 5、 2の画像 1 Momentary Switch Replacement, Determine voltage absence: 手順 5、 2の画像 2
    • Use a Duspol or any other two-pole voltage tester to test if there is voltage at the contacts.
    • Do not work on live circuits if you are not an experienced professional.
  5. Momentary Switch Replacement, Disconnect the wires: 手順 6、 1の画像 1
    • Disconnect the wires form the old switch.
    • If the old switch has Push-In contacts, you can unlock the terminals by pushing down on the plastic levers.
    • If you short Earth to Neutral you'll trigger your GFCI/RCD, even if the power is off.
  6. Momentary Switch Replacement, Connect the new switch: 手順 7、 1の画像 1
    • Connect the new switch. The new switch will typically mark where to connect which wire.
    • In (Phase Conductor/L)
    • Out
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sebastian
メンバー登録日: 08/19/18
32,863 ポイント
71のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 37
過去 30 日: 141
今までの合計 2,724
