はじめに
Follow this guide to remove and replace a faulty power cord in a Mk Diamond MK660 Wet Saw.
The replacement part is 153419.
Removing the motor before the power cord is not necessary, but makes the process easier.
必要な工具と部品
Loosen the plastic knob holding the saw's cutting head in place.
Lower the cutting head while keeping it steady.
Remove the Phillips #2 screw holding the ground wires to the chassis.
Loosen the wires from each other.
Remove the electrical tape from the twist-on wire connector connecting the three white wires.
