はじめに
If your Miyoo Mini Plus buttons aren't working well or just want to the replace them with different colors, this guide will help illustrate how to replace your old face buttons on your Miyoo Mini Plus with new buttons, this will give you the step-by-step process of taking your console apart to put in new buttons. We hope this helps!
Before beginning, make sure to power off the Miyoo Mini Plus and disconnect it from any external power source.
必要な工具と部品
Place the device face down on your work surface.
Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
3 の人々がこのガイドを完成させました。
1件のガイドコメント
The #00 Philips bit was too small for the screws on my device, and I found that the #1 Philips bit was the correct size. Also worth mentioning that the two motherboard screws were eventually eliminated from newer devices, so some users may not find screws in those two holes.
