メインコンテンツにスキップ
Mitsubishi WD57734 Back Panel Replacement
必要な工具と部品
  1. Mitsubishi WD57734 Back Panel Replacement, Lamp: 手順 1、 1の画像 1
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Mitsubishi WD57734 Back Panel Replacement: 手順 2、 1の画像 1
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. Mitsubishi WD57734 Back Panel Replacement: 手順 3、 1の画像 1
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  4. Mitsubishi WD57734 Back Panel Replacement: 手順 4、 1の画像 1
    • Using the handle, pull the lamp housing straight back out of the television.
    • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
  5. Mitsubishi WD57734 Back Panel Replacement, Back Panel: 手順 5、 2の画像 1 Mitsubishi WD57734 Back Panel Replacement, Back Panel: 手順 5、 2の画像 2
    • Remove the following 8 Phillips #1 screws:
    • One 22 mm Phillips #1 in the bottom right corner of the back panel.
    • One 18 mm Phillips #1 in the top middle of the back panel.
    • Six 18 mm Phillips #1 in the rest of the back panel.
  6. Mitsubishi WD57734 Back Panel Replacement: 手順 6、 1の画像 1
    • Pull the back panel off of the television by gripping the sides and rotating it down.
終わりに
作成者
5人の作成者と共同で作成されました。
Herman Chai
メンバー登録日: 10/02/12
196 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 18-39, Regan Fall 2012 Cal Poly, Team 18-39, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S18G39
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 1,055
