メインコンテンツにスキップ
Mitsubishi T200 Screen Replacement
必要な工具と部品
  1. Mitsubishi T200 Screen Replacement, Screen: 手順 1、 2の画像 1 Mitsubishi T200 Screen Replacement, Screen: 手順 1、 2の画像 2
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. Mitsubishi T200 Screen Replacement: 手順 2、 1の画像 1
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Mitsubishi T200 Screen Replacement: 手順 3、 1の画像 1
    • Separate the front plastic component from the motherboard component.
  4. Mitsubishi T200 Screen Replacement: 手順 4、 1の画像 1
    • Take the circuit board off the motherboard.
  5. Mitsubishi T200 Screen Replacement: 手順 5、 2の画像 1 Mitsubishi T200 Screen Replacement: 手順 5、 2の画像 2
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  6. Mitsubishi T200 Screen Replacement: 手順 6、 2の画像 1 Mitsubishi T200 Screen Replacement: 手順 6、 2の画像 2
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  7. Mitsubishi T200 Screen Replacement: 手順 7、 2の画像 1 Mitsubishi T200 Screen Replacement: 手順 7、 2の画像 2
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  8. Mitsubishi T200 Screen Replacement: 手順 8、 1の画像 1
    • Clip the new screen onto the circuit board.
  9. Mitsubishi T200 Screen Replacement: 手順 9、 1の画像 1
    • Replace circut board back on top of motherboard.
  10. Mitsubishi T200 Screen Replacement: 手順 10、 1の画像 1
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  11. Mitsubishi T200 Screen Replacement: 手順 11、 1の画像 1
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  12. Mitsubishi T200 Screen Replacement: 手順 12、 1の画像 1
    • Firmly replace screws into the backing.
ゴール
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Taylor Lewis
メンバー登録日: 02/13/14
14 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-5, Meza Spring 2014 Ohio State, Team 1-5, Meza Spring 2014人のメンバー
OSU-MEZA-S14S1G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 804
