メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
  1. Lift the black cover off. Remove all 4 Phillips #2 screws. Remove all 4 Phillips #2 screws.
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Remove the two 24mm Phillips #2 screws.
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Lift the back and pry the back off. The panel is held in with clips on the side. It needs a lot of force the take it off. The panel is held in with clips on the side. It needs a lot of force the take it off.
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Remove the four 5mm nut screws. Remove the four 5mm nut screws.
    • Remove the four 5mm nut screws.
  5. Remove the seven Phillips #1 screws. Remove the seven Phillips #1 screws.
    • Remove the seven Phillips #1 screws.
  6. Remove the three Phillips #2 screws. Remove the two data/power cables.
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Pull the two tabs. Pull the connector off. Pull the connector off.
    • Pull the two tabs.
    • Pull the connector off.
  8. Remove the switch cable off. Remove the two Phillips #2 screws.
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Remove the four display power cables. These cables are interchangeable.
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Lift the display out. Lift the display out. Lift the display out.
    • Lift the display out.
  11. Remove the four Phillips #2 screws. These screws release the display from its enclosure. Hold the screen when removing these screws.
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Remember to plug in all the cables on the display. Remember to plug in all the cables on the display.
    • Remember to plug in all the cables on the display.
終わりに
ある他の人がこのガイドを完成しました。
Padraic Hoselton
メンバー登録日: 2017年08月22日
3,636 ポイント
13のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
295 メンバー
972のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 84
